what motor is better a 70 l-65 or 85 lt-9 motor
Old Oct 19, 2010 | 05:35 PM
IZIBAKEMIZI's Avatar
Car: 89 gta
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt 383
i have these 2 sbc 350 and i wana make the most power i bought a voodoo 60102 cam what should i do
Old Oct 19, 2010 | 05:38 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: what motor is better a 70 l-65 or 85 lt-9 motor
What is a LT9? The L65 is just a plane 350 that made crap power.
Old Oct 19, 2010 | 05:47 PM
Car: 89 gta
Engine: 357
the lt9 came out ofa 1ton pick up 4bolt main but only 160hp 260 torque compare to 225hp 260 toque
The RPO codes for old motors are not useful, they are a waste of bandwidth. Most likely those motors aren't whatever those used to mean any more anyway.
What head castings are on them? What pistons are in them? THAT'S what makes a difference. Especially since the odds of a 70 ANYTHING still being whatever it was originally assembled as, are quantum-mechanically tiny. I'm guessing that's more than twice as long as you've been on the planet?
That said, you should put the cam in a motor. It will make very little power otherwise. I would pick the one with the better head castings and the higher compression, especially if it's in better condition. If that one is not in good shape, I'd restore it, or find another.
Old Oct 19, 2010 | 05:51 PM
Car: 89 gta
Engine: 357
so take the heads that have bigger intake and ex
Old Oct 19, 2010 | 05:52 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
I would have to agree that the one in best shape with the best heads is the one to use. You also cant take horsepower seriously from a 1970 engine. The ratings were way too optimistic.
Old Oct 19, 2010 | 05:54 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
nah if they are not good to run as is spend the money on vortec heads. They are gonna cost about what redoing the old ones will.
Old Oct 19, 2010 | 06:27 PM
No...
350 heads pretty much all came with 1.94"/1.50" valves. Only a rare few came with anything else (and most of those, it was worse; although if you have a truck motor, that's a possibility). That's not usually a valid test.
Use the ones that are the better castings to begin with.
No 70s 2-bbl smoggers, for example (882, 993, 624, no matter what valves have been jammed into them); no early 305 heads; no "swirlies"; that sort of thing.
Old Oct 19, 2010 | 06:28 PM
Car: 89 gta
Engine: 357
both head are in damn good shape the one set are 3998993 and the other is 14079261 which is better
Old Oct 19, 2010 | 06:36 PM
Car: 89 gta
Engine: 357
well found out that the 3998993 sucks and dont use them
Old Oct 19, 2010 | 06:43 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
sounds about right
Old Oct 19, 2010 | 06:45 PM
Car: 89 gta
Engine: 357
so port and polish the 14079261 and run them
Old Oct 19, 2010 | 06:53 PM
Mang... that's a tough one....
Both are 70s DEEP smogger heads. 993 of course is one of the ones I specifically mentioned; 261 could be either a mid-70s 2-bbl head or a mid-80s truck head, likely to have 1.72" intakes. Yuck.
Which smells worse; monkey dung, or anteater dung? Hmmmm.........
Sounds like it's time to dispose of some scrap cast iron, see what pistons are in the blocks, and what shape the motors are in generally, and go head-hunting.
Old Oct 19, 2010 | 07:46 PM
Car: 89 gta
Engine: 357
which ones are better
Old Oct 19, 2010 | 07:48 PM
Car: 89 gta
Engine: 357
looked them both up and the 3998993does have 1.78 but the other has 1.94
Old Oct 20, 2010 | 05:49 AM
Valve size isn't the problem.
Anybody can jam any size valves into any casting. Doesn't make the casting any better. Doesn't fix what's inadequate about the casting, which is the ONLY thing that matters. Everything else is repairable.
Neither of those is a useable basis for any kind of a performance build. Forget about them and find something better. Trying to build a "fast" motor out of either will produce nothing but disappointment and a waste of money.
Steve78LT
Feb 24, 2016 12:15 AM
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
