34 MAP sensor circuit error (signal low indicating high vacuum)
Old Oct 22, 2010 | 11:22 AM
86 Camaro joe's Avatar
Car: Camaro
Engine: 2.8 tune port
i have a 2.8 86 camaro ,
my check engine light turned on
and told me 34 MAP sensor circuit error (signal low indicating high vacuum)
but my car runs fine no problems ?
so i disconnected my battery to reset the car to get the light off
and started it , it was running rough so i restarted it,
than my check engine light turned
back on and started running perfect again ?
limp mode ??
it drives perfect tho ....
same power and everything ,
Old Oct 22, 2010 | 11:29 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 34 MAP sensor circuit error (signal low indicating high vacuum)
Don't you have MAF not MAP? May need cleaning??
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
91REDZ28VERT
Aug 18, 2015 10:16 PM
squiggy2
Aug 9, 2015 09:30 PM
