Temp gauge problems
Old Oct 23, 2010 | 08:06 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
Temp gauge problems
When I go to start the car,my temp gauge will go from 100 to past the max mark,about 3o clock position.
After searching my driver side head has a plug where the sender should be and my pass head has some kind of sensor/sender on it,but it is unplugged.
Why would the gauge move when I start the car but wont go up/down with the temp?
Does anybody know the color wire under the hood that goes to the gauge?
The PO did an engine swap so its a mess under the hood
Old Oct 23, 2010 | 08:50 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: Temp gauge problems
You say the gauge sensor is unplugged.... so where is theconnector? See if its not grounding somewhere else, a grounded coolant temp sensor will read all the way up.
Old Oct 23, 2010 | 09:30 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
I dont know what the connector looks like or the color of the wire. The gauge only reads all the way up when cranking the car. It goes back to 100 when the car is running.
Old Oct 24, 2010 | 06:22 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
I believe it is normal for the gauge to sweep like that on start up, a check to make sure the gauge is operating properly.
Old Oct 24, 2010 | 06:44 PM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
Mine doesn't sweep like that.
Ghettobird52
Jul 5, 2024 11:18 PM
Bstrang6
Sep 8, 2015 04:29 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
bamaboy0323
Aug 15, 2015 07:20 AM
