Carb guys
Old Oct 24, 2010 | 06:42 PM
89F Body's Avatar
Car: 89 z
Engine: 96 350 HSR vortec
Transmission: 700R4 24-2800 BDR stall
Axle/Gears: 9 bolt disc posi w/3.45
Carb guys
Ok so you guys that swapped to carb and are still using the TPI pump, I have a question for you.Did you use the stock return line or switch to a braided stainless hose?I am debating the swap even though Ive got all the EFI stuff but am not sure on the power out come.Im running a zz1 cam in a vortec block with 906 heads im porting and and HSR that ive already ported.
Infested
May 22, 2018 11:56 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
Street Lethal
Aug 14, 2015 08:25 PM
