Fuel Tank Problems... Please Help!!!
Old Oct 24, 2010 | 09:54 PM
IROCNPCOLA's Avatar
Car: 1989 IROC Z28
Engine: 5.0 TPI
I have a 1989 IROC with a 5.0 TPI engine. I have replaced the fuel pump with a new Delphi pump because after the car has been driven and gets really warmed up I have a noise coming from the tank. It is doing the same thing with the new pump as with the old one. It sounds like the pump is loading or binding or something. A fuel pressure check while it is making it's riduculous racket showed normal pressure. Sometimes you can smell gas but not always. I have replaced all 8 injectors, checked fuel lines for blockage, replaced filter, replaced fuel tank vent valve and the purge valve on the cannister. Has anyone had this problem and if so please tell me what is going on. The car is possessed!!!
Old Oct 24, 2010 | 10:14 PM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
Re: Fuel Tank Problems... Please Help!!!
I have had a bad AC pump off the shelf.
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Glowsock
Aug 26, 2015 12:28 AM
AkDrifted
Aug 17, 2015 07:45 PM
