Vortec heads... Some questions
Old Oct 24, 2010 | 10:45 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
My knowledge with these is limited, so please bear with me.
Essentially, what "mods" do vortec heads respond well to?
To be more precise, is it worthwhile to increase the exhaust valve size to a 1.60" valve?
I'm also wondering approximately what gains could be seen by upgrading to full roller rockers, and what roller camshaft profiles work well with a 1.5 ratio rocker and these heads. Compression ratio should be around 9:1 give or take
I'm looking more for good torque and driveability, power above 5000 RPM's is not especially important.
Supposing I used this cam: http://www.summitracing.com/parts/CCA-12-410-8/ with 1.5 ratio full roller rockers , 1.60" exhaust valves, an Edelbrock performer intake manifold (carbureted), and shorty headers, 9:1 compression.... Does this seem like the parts are reasonably well matched to each other? Any estimates on numbers this might put out on a 350?
Thanks!
Old Oct 25, 2010 | 03:59 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Vortec heads... Some questions
There are two things these heads need more than anything - cut the valve guides down to allow more valve lift, and some port work on the exhaust side. Intake side breathes fine, but the exhaust needs help.
Old Oct 25, 2010 | 03:50 PM
I was taking the machine work for cutting the guides down as a given, I'd rather do that than run beehive springs personally.
What port work are you talking about in particular? Just the typical smoothing/radiusing the guide boss & de-shrouding the valve? Or something else in specific?
Also, anyone have any estimates on the numbers the parts combo above might make, torque in particular?
Old Oct 25, 2010 | 04:26 PM
Air_Adam's Avatar
Ya, just the typical kind of port work on the exhaust is fine.
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
z28addict8490
Sep 5, 2015 03:56 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
