easy 305 h.p?
Old Oct 27, 2010 | 10:15 AM
droste's Avatar
Car: 92 firebird
easy 305 h.p?
whats an easy (and cheap) way to get some extra h.p out of the 305 tbi? its in my 92 firebird if that makes a differance
Old Oct 27, 2010 | 10:22 AM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Re: easy 305 h.p?
depends on what your definition of cheap is, but an exhaust, headers/catback will help some.
and although its not horsepower,
weight reduction will help, there are some thread and a technical article.
some gears in the rear, 3.42, 3.73, 3.90 will help
Old Oct 27, 2010 | 10:28 AM
droste's Avatar
Car: 92 firebird
Re: easy 305 h.p?
i would like to keep it under 500 i heard you can take the headers and exhaust of off a formula with the 350 and get like 40 h.p thats probably wrong though
Old Oct 27, 2010 | 10:29 AM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
Re: easy 305 h.p?
a cam is probaly the cheapest but a fair amount of work. with a cam headers/exhaust and new heads on your stock bottom end will give you a considerable amount of h.p. Google it there are a couple build ups done by I believe lunati and a chevy mag that were pretty impressive .
Old Oct 27, 2010 | 10:45 AM
droste's Avatar
Car: 92 firebird
Re: easy 305 h.p?
if i put a cam and a differant exhaust on how bad will it hurt mpg? im not that worried about it but would like to know
Old Oct 27, 2010 | 11:47 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: easy 305 h.p?
you definitely won't gain much grabbing other factory exhaust parts from these cars. if you dig through the classifieds, you can probably find headers and a y pipe for about $100. catback's definitely a good thing to do too. both are good starting places for future mods.
LT1 cams are pretty cheap (under $50 used) and will give you a little more power without making your computer go nuts.
Old Oct 27, 2010 | 01:25 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Re: easy 305 h.p?
No factory 3rd gens came with headers they had manifolds. You may pic up something going to 350 manifolds but not worth the hassle.
The Y-pipe is a huge restriction on a 305 car. It's 2 1/4 inch at it's widest and smashed much less then that in at least 3 places.
Also budget in a heated O2 sensor when you swap headers on a computer controlled car. Moving the O2 further away from the heads makes it much cooler and since they need to heat to a certain level to keep the computer in control you can see why this is ideal.
Good idea with the cheapo LT1 cam but laying a cam swap on a noob (no offense!) could be ugly. You could do it with enough patients and intuition but IMO it's not a good "first". Bust your knuckles up a bit doing the headers and exhaust before you jump into something like this.
A friendly note if you do end up going with the headers/exhaust replacing the cat when you do the Y-pipe will save you hours or frustration trying to get them apart. The cat is "slip on" to the Y-pipe and it's pushed about 4-5 inches deep lined with carbon. Real fun getting it out.
Old Oct 27, 2010 | 04:44 PM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: easy 305 h.p?
you are not going to get much from a 305 tbi.when i was like 17 i didnt listen to anyone either and tried buying part to make it fast i bought the edelbrock intake manifold, the holley tbi unit, full exhaust, under drive pulleys, and a hypertech chip. imo all a big waste of money. for that price you can buy a nice setup from like holley. look in to their mini ram with commander 950. buy that and an exhaust and you will be happy.
Old Oct 27, 2010 | 05:04 PM
Convoy25's Avatar
Re: easy 305 h.p?
yeah i'm just suggesting stuff that could benefit him if he does a swap down the road.
you can always port and polish the heads, there is a write up somewhere around here, and thats free if you have the tools.
Old Oct 27, 2010 | 05:16 PM
torque_is_good's Avatar
Re: easy 305 h.p?
step 1- get rid of the snorkel air cleaner
step 2, headers and y pipe
step 3 cat back (if you can afford it do 2 and 3 together)
then see if that's enough
gears make a car pull harder down low which is where you do most of your driving so you'd feel that on the butt dyno
Old Oct 27, 2010 | 06:18 PM
Doom86's Avatar
Re: easy 305 h.p?
No offense but you did it wrong only one of the things you listed was even worth buying. You wasted a lot of money on things that weren't bottle necks. The TBI and intake manifold are the last things that are holding you back and underdrive pulleys are not even on the list IMO. Don't even think about wasting money on any of that until you have swapped the cam and heads.
Just because you can see it and it's shiny doesn't make it faster.
Old Oct 27, 2010 | 09:11 PM
Convoy25's Avatar
Re: easy 305 h.p?
unless he has a cowl hood an open element air cleaner wont do better than a snorkel
Old Oct 27, 2010 | 10:03 PM
Re: easy 305 h.p?
Get a "bore kit" out of a 87-95 truck. Take the injectors, the chip, and the knock sensor that go with the kit.
Cheeeepest horsepucker money can buy.
Old Oct 28, 2010 | 04:19 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Re: easy 305 h.p?
The heads and exhaust manifolds on the TBI are terrible. A cam and heads swap, and exhaust upgrades are a good place to start, along with some custom tuning in the ECM.
Old Oct 28, 2010 | 04:28 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: easy 305 h.p?
Open her up and allow her to breath.... intake, headers, hi flow CAT, and exhaust... you're looking at about 900 parts alone... headers and exhaust should give you about 10 HP or so, maybe 15.1240834 hp... ..
Old Oct 28, 2010 | 11:33 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: easy 305 h.p?
Dual snorkel or open air cleaner and headers/exhaust are where you have to start. They are the biggest bottlenecks, so anything else you might do won't gain you much untill you do those first.
Old Oct 28, 2010 | 02:09 PM
Doom86's Avatar
Re: easy 305 h.p?
I think you are kidding, or hope at least
There is a a LOT of proof that adding headers and exhaust is good for at least 40hp on a 305 motor.
TBH though I've never seen a LO3 tested like this but having a LG4 and a LO3 I can tell you they have the same restrictive exhaust. My LG4 picked up a ET calculated 60hp over stock with headers, exhaust, intake (intake probably hurt more then help since it doesn't match the cam).
I don't think the "bore kit" (sofa you make me man) would even do that good for the investment and hassle in and of it's self. Now the full exhaust followed by the bore kit and/or at the same time would be great but all you really get is a low RPM stump puller either way.
Old Oct 28, 2010 | 03:06 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: easy 305 h.p?
Check my cardomain in my sig for the answers you seek, i'm to lazy to type this again. And yes you can make good power with an L03
Jake_92RS
Jan 28, 2020 10:37 PM
Keith5
Aug 27, 2015 04:37 PM
michealleger
Aug 26, 2015 03:29 PM
kyleb24
Aug 15, 2015 08:24 AM
st.evel07
Aug 13, 2015 06:15 PM
