car wont start, sputter, nothin in the rain
Old Oct 28, 2010 | 01:44 PM
woottang30's Avatar
Car: '89 Formula
Engine: 355 SBC, AFR 195s
Transmission: T-56 Swap
Axle/Gears: 7.5 Eaton LSD w 4.10s
just looking for a second opinion. car wont even try to start when it really wet out from rain or for a while after it rains. Im guessing its plug wires absorbing the moisture, but any other input would be greatly appreciated. thanks all
Old Oct 28, 2010 | 08:26 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: car wont start, sputter, nothin in the rain
Well, that's a good guess or it could also be a hairline crack in the distributor cap. Try spraying it down with some WD40. That will displace the moisture and it should crank then. If it does, then you can replace it or the wires. My brother had an old Pinto that had that problem and that's where I learned this trick from.
Old Jun 2, 2015 | 09:01 AM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Hey, I'm currently having the same issue. My 92 RS will crank, and crank but will not turn over. This has only happened since the rain has been heavy in my area. Did replacing the wires work? Were there any other suggestions?
Old Jun 2, 2015 | 10:33 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
you guys could try spraying WD-40 around the cap and wires one at a time and see if she'll start. Whichever one sprayed before it started is your culprit and should be replaced
Old Jun 2, 2015 | 11:05 AM
Engine: 305 / 350
@iroczracer07 - I will be doing that. I just bought the car, and I believe its been sitting a while...I'm assuming it'll be worth changing plugs, wires, distributor cap & rotor and ignition coil in efforts to prevent this going forward... Your input and advice is appreciated
Old Jun 2, 2015 | 11:13 AM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Yep sounds like a cracked distributor cap. changing the cap, rotor, plugs, and wires is definitely worth the money due to the age of these cars
Old Jun 2, 2015 | 11:18 AM
Engine: 305 / 350
@TylerSteez - Thank you, any input on the ignition coil?
Old Jun 2, 2015 | 11:28 AM
TylerSteez's Avatar
Engine: 383 stroker
Not sure if I could help you with that, I've never had to replace mine. I'm pretty sure that certain auto parts stores can test them for you
Old Jun 2, 2015 | 12:32 PM
Drac0nic's Avatar
My opinion is go to a dark place, crank and see if anything lights up. In a lot of cases you'll have a spark show. Plugs/dist cap/rotor (brass contact) are a good start. Get some NGK, Delco or Autolites. You don't really need anything high $$. If you go with high $$$ stick to say Delco plats and skip anything gimicky. Another thing you can do is try to shoot some carb cleaner into the carb/throttle body and see if it fires. If so, you need to look for fuel issues and not ignition ones.
Old Jun 2, 2015 | 12:42 PM
Engine: 305 / 350
@Drac0nic - Thank you, I haven't tried Carb Cleaner in the TB yet. I may try a few things when I get home this evening. Feel free to check out my YouTube Video
this is what I got after replacing the Alternator, Fuel Pump, SMOG Pump w/ AIR Management Valve. If the link doesn't work please E-Mail me at ewitcher06@gmail.com so I can send a direct link. I NEED ALL THE HELP I CAN GET lol
Wade787b
Sep 29, 2015 01:15 PM
mustangman65_79
Aug 11, 2015 03:17 PM
apie2546
Aug 10, 2015 05:43 PM
87350gtanj
Aug 8, 2015 10:32 AM
