Packaging mistake on King Engine bearings part
Old Oct 29, 2010 | 03:28 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I bought a set of king engine bearings awhile back, and the rod bearings have a chamfer for cranks with large radius journals. I have a standard stock cast iron crank, which doesnt need the chamfers. But, they sent me two sets of upper rod bearings, so when installed, the chamfer for the lower half of the rod bearing is on the inboard side of the rod. The other side of the bearing is the same as a stock one, so it doesnt cause any interference issues. Can I still run these like this? Cant return them, and Im running out of cash to finish the build.
I cant see it causing any problems using them, but is there any possible issue to running them like this?
Old Oct 29, 2010 | 11:45 AM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: Packaging mistake on King Engine bearings part
Hmm, boy I gotta tell ya that makes me uncomfortable.
Not something I would do on a customers build.
For my own it would depend on the severity of service, ease of access & if it is to be the only DD.
IOW I might try it in a pinch on my own non critical build, any other & I need the right parts.
Issues are, top shell on the bottom if any grooving, & parting line mismatch (could affect oil sling, create tiny tight or hot spot).
Thats all that comes to mind right now, these engines are very forgiving when built & operated conservatively.
Old Oct 29, 2010 | 08:37 PM
Car: 88 Camaro SC
Engine: SFI'd 350
FWIW, both the top and bottom shells for a SBC are the same before machining with a chamfer on one side for the radius. My concern is that the chamfer already decreases the footprint of the bearing, and possibly having them on both sides could reduce it even farther by allowing the oiling at the outer edges of the bearings to break down.
Old Oct 30, 2010 | 12:03 AM
xch3no2's Avatar
Transmission: TH400
Ya Imma tryin, to say mostly the same thing, groove alignment & oil control, how big of a chamfer are the bearings cut for?
Old Oct 30, 2010 | 01:08 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Decent size, at least 3-4% of the bearings footprint is reduced by the chamfer. I guess Im going to have to bite the bullet and buy another set. They better send me both halves this time around...
Old Oct 30, 2010 | 06:49 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
If its a packaging mistake wont they take them back?
Old Oct 30, 2010 | 07:50 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Actually, I think summit packaged them using king as a supplier. I bought them a LONG time ago as the summit in-house brand, and the reciept is long gone, so, theyre mine, now. It didnt occur to me at the time to check to seee that the chamfer is in the right place. The boxes where just white and unlabeled.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1nastygta
Aug 8, 2015 07:38 PM
