Poor Fuel Economy?
Old Nov 1, 2010 | 05:48 PM
comeau331's Avatar
Car: 1986 Trans Am
Engine: Stock 305
Axle/Gears: not sure...
Poor Fuel Economy?
After much work I've assembled all the pieces and got my 86 trans am running decently. I'm only getting around 12-14 MPG's though. What should I expect to get for fuel mileage? Its a cc-qjet/305. The CEL is on for a bad TPS sensor, could that be killing MPG's? The choke works fine so I know its not sticking. With fuel economy this poor I may have to sell it!
Old Nov 1, 2010 | 06:43 PM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Re: Poor Fuel Economy?
thats not all that bad. A bad TPS could hurt mileage but not a big bunch. Keep in mind it is a carbed engine so milage will be way different than injected.
Old Nov 2, 2010 | 08:51 AM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
What have you done to it/removed from it? Its also a lot on how you drive. Is the trans shifting into fourth and/or locking up? How about EGR function that helps fuel economy as well. Oh, replace the TPS. That way you know if any more codes pop up.
colton_carlson
Mar 8, 2019 12:21 PM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
