Start from wiring under dash
Old Nov 4, 2010 | 02:06 PM
TA-Rocks's Avatar
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
How can I start my car temporarily until I get the new steering column installed? I have a bad steering column assembly and will replace it but need to know which wires I can use with my key in ignition to start the car. It has vats and the proper key. Anyone know which wires will start it?
Old Nov 4, 2010 | 05:29 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Start from wiring under dash
Jump big yellow wire to big purple wire - you can also do it under the hood by applying 12v from battery to the terminal where the purple wire attaches to starter.
Old Nov 4, 2010 | 05:41 PM
TA-Rocks's Avatar
Thanks I will try that and let you know
Old Nov 6, 2010 | 08:42 AM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Last I recall, on an 89 T/A the power wire is a big red one and the starter wire is a big yellow one in the ignition switch harness.
Ghettobird52
Jul 5, 2024 11:18 PM
Jorlain
Aug 24, 2022 05:11 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Street Lethal
Aug 14, 2015 08:25 PM
stalkier
Aug 13, 2015 12:59 PM
