2nd gen problems
Car: 91 Firebird, 89 Bird, 86 Bird
Engine: None, 5.7, 5.0 L.O.
Transmission: None, T5, Thm 350
Axle/Gears: 3.23, 02' 3.43 rear disc, ???
2nd gen problems
First off I know this isnt a site for 2nd gens but I cant find any help anywhere else and a car is a car. But onto the point My friend has a 77' Firebird and his turn signals dont work his left turn signal indicator dont work and when he tries to turn on the turn signal the corresponding brake light goes out. And his Heater doesnt work on high and only blows out defrost, the heater problem is a bad relay and a vaccum leak right? anyway any help is appreciated
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Re: 2nd gen problems
It seems that requests for info on 2nd gens are so common that I wonder, is there really no "2ndgen.org" or equivalent? Must tell you something about those cars if there isn't one for them... but there is for us.... something to think about!
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The defrost issue means a vacuum leak - the switches that divert the flow from floor to vent to defrost are vacuum controlled, when there is not enough vacuum to work the switch, the default setting is defrost.
On signals I'd start with a complete 4 corner bulb replacement (because it's easy), and while there verify all the ground contacts on each bulb socket, then check the flasher under the dash and replace, then I'd check into the operation of the turn signal switch.
Car: 1974 Camaro Z28 Type LT
Engine: 350 sbc
Transmission: Borg Warner T5
There is one. It's nastyz28.com
Omega
Oct 1, 2015 02:20 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
