changing a computer in a 91 Rs?
Old Nov 5, 2010 | 10:06 PM
birdman_29's Avatar
Car: 84 Z28 Camaro
Engine: Z28,305
Transmission: 700R 4
Axle/Gears: stock
I'm gonna be changing out the dash instrument panel and computer in my car, I've already taken out the dash instrument panel before but never have gotten to the computer. How hard is it to get too? Does it consist of taken out the whole dash or just the dash board?
Old Nov 5, 2010 | 10:41 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: changing a computer in a 91 Rs?
You should only need to take out the under-dash panel on the passenger side. The computer is right above that panel, mounted vertically.
Old Nov 5, 2010 | 11:39 PM
Zeromitch87's Avatar
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
I just changed mine out the other day its easy. Unplug battery before you pull out the wires into the computer i didn't do this and everything is fine but just to be safe i would. The wires plugged into the computer can be a little struggle to get off until you figure it out good luck and have fun
Old Nov 6, 2010 | 08:52 AM
birdman_29's Avatar
Car: 84 Z28 Camaro
Engine: Z28,305
Axle/Gears: stock
just to clarify I just need to take out the dash part under the dash board, on the passenger side? I have always thought it was one big piece and then everything else is added on like the instrument panel and dash board etc. Looking back on your reply did you mean even lower near the heater motor?
Old Nov 6, 2010 | 09:02 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Yes, way down underneath the dash. Down where you feet go. Its a couple of Torx screws IIRC. It's been a while since I removed that panel and I've never gotten around to putting it back. Basically, the computer is mounted right behind the RS/Z28 logos on the dash.
Old Nov 6, 2010 | 09:07 AM
birdman_29's Avatar
Car: 84 Z28 Camaro
Engine: Z28,305
Axle/Gears: stock
thanks for the information, it is in the plans to do tonight.
eightsixseven
Dec 16, 2024 01:50 PM
z28addict8490
Sep 5, 2015 03:56 PM
86IROC112
Aug 21, 2015 07:20 PM
jharrison5
Aug 19, 2015 05:53 PM
perZ
Aug 15, 2015 01:17 PM
