Oh ****!
Old Nov 8, 2010 | 01:47 PM
stillwell's Avatar
Oh ****!
guys i have a mess!!!!got new 5.7 in bottom plentium on top just sitting on i have plastic lines every where and little hoses need more detail pic like off the pass side rear has a rubber thingy and 2 plastic lines,egr under plentum,and 2 comeing out of pass side harness???????please send a close up or anything that mite help!thanks for all and any help
Old Nov 8, 2010 | 01:52 PM
Stephen's Avatar
Car: 87 GTA
Re: Oh ****!
If I had a clue as to what you said...Or tried to say? I'd try to help.....
Old Nov 8, 2010 | 02:21 PM
stillwell's Avatar
Re: Oh ****!
i have vacume lines in a pile.thats how i got this car.need a vacume line picture and hose picture.87 z28
Old Nov 8, 2010 | 02:23 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: Oh ****!
There should be a vacuum line illustration attached right your hood.
Old Nov 8, 2010 | 02:48 PM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
Re: Oh ****!
WOW! I tried too. I didn't do any better.
Try compnine.com and see if they have what you need.
Old Nov 8, 2010 | 02:50 PM
stillwell's Avatar
Re: Oh ****!
no i look'd there first cheap model i guess! i found an older post with 87-89 not like mine.cc line goes to the top plenium 2nd to last male end.so it shows. but mine looks all factory still dirty.On the passanger side toward the firewall i have 2 plastice lines comeing out of the wireing harness,1 has an rubber elbow,the other goes i think to the heater control valve with the 2 big hoses attach'd to it.?Also have a small cylinder with 2 small lines(looks like a one way valve or something in that order.it will not have a/c,or emissions box that goes pass side #2 cylinder.hope this makes sense??lost right now.
Old Nov 8, 2010 | 02:55 PM
jwande's Avatar
Engine: 305 TBI
Re: Oh ****!
I'm still not doing any good. Can you attach pics so we can see what you're seeing?
Old Nov 8, 2010 | 03:00 PM
jwande's Avatar
Engine: 305 TBI
Re: Oh ****!
After re-reading, I think you are over by the EGR valve. That should have a vacuum line. Your MAP sensor should have a vacuum line. The EGR control solenoid will be there as well. Your heater control valve has a vacuum line.
We need the following:
Year of car
Year of engine now
Year of engine in car originally
Size of engine and fuel system (TPI,TBI,carb)
Can you put some space between your thoughts? By the time you have switched gears I am still grinding away and didn't know we were on a new sentence. Sorry - could be my age.
Old Nov 8, 2010 | 06:17 PM
stillwell's Avatar
Re: Oh ****!
sorry man. what i have was an 87 305 tpi. now i have an 87-90 5.7..i have pics mite take me a while to get them up. owner just went and got some hose,alt bracket,and misc stuff. I'll take a few pics in a few and try to post them for ya thanks for ur help with this. My hot rod is a bandit 79 t/a 6.6 NO computer crap!lol hang tight.
Old Nov 8, 2010 | 07:31 PM
stillwell's Avatar
Re: Oh ****!
<a href="http://s751.photobucket.com/albums/xx155/screamnta/?action=view&current=100_1187-1.jpg" target="_blank"><img src="http://i751.photobucket.com/albums/xx155/screamnta/100_1187-1.jpg" border="0" alt="Photobucket"></a>
Old Nov 8, 2010 | 07:33 PM
stillwell's Avatar
Re: Oh ****!
how do i put up pictures guys???have them in photobucket already?
Old Nov 8, 2010 | 10:59 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Oh ****!
Put a link to the pic inside these tags [img*][/img*] (without the *)
Old Nov 10, 2010 | 07:00 AM
stillwell's Avatar
Re: Oh ****!
all done guys runs awsome!well almost need a MAF code 33. try'd to clean the wires inside.help'd out the rough start but runs rich eyeballs burning.been sitting for a yr.thanks for all ur hep and getting back 2 me.off i go to do some cruz'n and break in.
Old Nov 11, 2010 | 02:04 AM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
Re: Oh ****!
Lol Stillwell, you're like Dr. jekyl and Mr. Hyde, your posts are extremely illegible and then you make complete sense in the next post and then it's back to, "what did he just write" ?
Glad you figured it out!
Old Nov 11, 2010 | 07:38 AM
stillwell's Avatar
Re: Oh ****!
lol sorry hard to explain.car runs very good.bad maf is there any way of bypassing it?,i think there is a non maf in 85 or something.ran it around block last nite.rough till 2000 rpms and just puts you sideways at the push of the gas!maf is 150 bucks.I clean'd the wires in the maf unit better but runs rich,burns my eye's.any ideas
