Water Temperature Gauge Not Working
Old Nov 9, 2010 | 10:57 AM
Rajin's Avatar
Car: 1974 Camaro Z28 Type LT
Engine: 350 sbc
Transmission: Borg Warner T5
Last night I went and changed the O2 sensor on my car. Now the temperature gauge isn't working. Is there any wires around the O2 sensor that I might have bumped that could cause this?
1989 Pontiac Firebird w/ 305 TBI
Old Nov 9, 2010 | 01:57 PM
corey13's Avatar
Car: 88 camaro
Engine: 5.7
Re: Water Temperature Gauge Not Working
if you disconnect the connector for the temp sensor there should be 2 pin slots, if you short them out (useing a paper clip, piece of wire, etc) and turn your ignition to the accessory spot, your gauge should peg out to the max. if it doesn't do that, then that means that you have bad wiring or gauge, if it does, you have a bad temp sensor.
Old Nov 9, 2010 | 02:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The temperature gauge sender is in the driver side head between #1 and #3 cylinders. It's possible you could have disturbed the wiring.
Old Nov 9, 2010 | 05:23 PM
Rajin's Avatar
Engine: 350 sbc
That's exactly what it was.
Thank you
Old Nov 28, 2010 | 06:04 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
do you have a picture of that wire? my gauge pegs when cranking but it wont ever move? is that a sign of a bad sensor?
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
justin57
Aug 20, 2015 07:05 PM
