camaro has the hiccups
Old Nov 10, 2010 | 06:50 PM
kjen's Avatar
Car: 1992 camaro rs heritage edition
Axle/Gears: stock
i have a 92 tbi 305, my problem started a couple weeks ago when cruizing down the highway it would spit and sputter...not all the time just once in a while, now it even does it when its sitting there idling, hasnt thrown any codes, i changed the ignition module, checked fro vacum leaks still cant figure it out....any suggestions would be thankful
Old Nov 10, 2010 | 09:10 PM
wwwyzzerdd's Avatar
Car: 1988 IROC Z
Engine: 350 5.7L Carb'd
Axle/Gears: Disc 2.77
Re: camaro has the hiccups
fuel filter?
Old Nov 11, 2010 | 02:53 AM
Sexonfire14's Avatar
Car: 88 GTA
Engine: 350 tpi
might have a misfire. check plugs. ohm injectors. should be 16 ohms.
Old Nov 11, 2010 | 02:56 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Could be fuel injectors
Old Nov 11, 2010 | 04:36 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
check fuel pump, maybe your not getting enough gas, also fuel filter and plugs like everyone else said
Old Nov 11, 2010 | 04:48 PM
Tonysz383's Avatar
Car: 88 IROCZ 350
Engine: 355 cu TPI
Transmission: 4L60 w/ 3200 stall
Axle/Gears: 9 bolt W/370 gear
I don't know much about TBI, but I don't think that the injectors are high impedance.(16 ohms) Look on line for the impedance values to be shure. How many miles do you have? If your fuel pump is weak it will cause symtons like yours. Also dirty fuel injectors will do it. I always tune the car up so I know that thinks like plugs, rotor and cap, wires and fuel filter are out of the question. one more thing, some times you may get contaminated fuel from a gas station, you know water in the gas, that will cause you problems too.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
