exhaust backfire at start up, now misses under load
Old Nov 10, 2010 | 08:31 PM
Xslow 383X's Avatar
84 camaro. 400 small block. Sportsman 2 heads. Victor Jr. Intake. Summit 1108 cam. HEI dizzy. Long Tubes. Holley Black Electric Fuel Pump. Holley 750 DP. 4.5 power valve,about 9psi of vacuum at idle. T5 Tranny. Fuel pressure at 7psi. Need to know anything else just let me know.
So I parked the car with no problems. Came 2 days later to start the car, and it started backfiring like crazy. It cleared out for the most part, but when driving it you can almost feel a small miss but under heavy acceleration it backfires some and what i think may be it missing sometimes worse than others and just doesnt seem to have the power it did. Things iv tried are: 2 different coils,shut the lights off with the car running and saw no arcing, plugs have the blackness to them where you can tell the car was running rich..even though it acts as if its leaning out the more i lay into it.
Any ideas?
Old Nov 10, 2010 | 08:37 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: exhaust backfire at start up, now misses under load
backfiring from intake or exhaust? could be valve adjustment or bent valve or ignition timing issue to name a few
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
db057
Aug 22, 2015 08:17 PM
drathaar907
Aug 6, 2015 04:20 PM
