Won't turn over help!!
Old Nov 10, 2010 | 12:29 PM
shanewbenson's Avatar
Car: 1992 RS
Engine: 305 TBI
Transmission: IROC 700R4
Ok guys I really need your help my daily driver is down!! I drive a 92 camaro 305 tbi. it was driving fine and I keep up on all maintenance but i stopped to get gas and when i was gonna pull away she wouldnt start. Not even try to...its not turning over at all. all the fuses are ok and i replaced the battery and starter. Its had a full tune up recently including all plugs wires cap rotor fuel filter ignition module and i can hear the pump priming. When i turn the key to the on position and jump the starter solenoid it turns over but wont start. I suspect an electrical issue somewhere. Any ideas? Please Help!!!
P.S. I bypassed the vats system with a resistor so could anything else be going on with that?
Old Nov 10, 2010 | 05:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sure sounds like a VATS issue. You need to start tracing down where you have start voltage and where you don't.
Old Nov 11, 2010 | 03:05 AM
Sexonfire14's Avatar
Car: 88 GTA
Engine: 350 tpi
Re: Won't turn over help!!
you replaced both battery and starter? why? lol get a dvom and do voltage drop on the positive and negative cables. should have close to 0. if any are high, you know you are losing voltage somewhere. i bet its just a bad connection.
Prodigious
Nov 7, 2020 09:23 AM
Derick15
Sep 17, 2016 05:28 PM
WIzmo
Aug 30, 2015 02:30 PM
ZsTransAm
Aug 11, 2015 07:30 PM
BrianI
Aug 9, 2015 11:52 AM
