Anyone have experience with the stock crankshaft?
Hey guys, just looking for some input. Has anyone here pushed the stock crankshaft in a 91 350? Im looking to do a build and im wondering how far I can push the stock crankshaft. Any good advice appreciated.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Anyone have experience with the stock crankshaft?
How far do you want to push it? 600 HP should be doable in a well-built engine.
Engine: 383 Carb
Transmission: 4L60
Not an issue if the crank is in good condition.
Car: '82 Z28
I'm running a stock GM crank in a 2 bolt main block, no issues so far in the 7 years it's been together. It's held up to whatever horsepower it's making plus a 200 shot of nitrous spinning 7000 - 7300 rpm.
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Impressive and I thought I was beating the crap out of mine lol.
stock cranks can hold a bit of abuse but if you need to have it cut and polished, with the cost of labor you are pretty much in the same price range to just buy a new, even stronger crank from eagle or others.
LT1Formula
Aug 20, 2015 09:36 PM
