air/fuel ratio guage?
Old Nov 14, 2010 | 11:45 PM
Dr. Phil's Avatar
Car: 1987 Pontiac Firebird GTA
Engine: 383
Axle/Gears: 3.42 10 Bolt
My engine is carburated and I would like a wideband O2 gauge to monitor the AFR while tuning the carb so I can get everything spot on. Does anyone have any recommendations for a good one. I dont like to be a cheap skate, but the cheaper the better! I have all autometer pro comp ultra lites guages right now, does autometer make an AFR guage in that series?
EDIT- i forgot to ask another question. My fuel guage only goes to 3/4 tank at full and goes all the way down to the e and stops moving when i still have at least 5 gallons in the tank. I have an autometer guage (fuel level) that was in the car when i got it, if i connect this guage will it fix the problem or is it most likely the sender?
Old Nov 15, 2010 | 03:07 AM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
Re: air/fuel ratio guage?
I just installed an air fuel guage. I wanted a wide band too but settled for a cheapo narrow band one after I found out what wideband o2 sensors and gauges cost.
It seems to work ok, I gained a couple of MPG. I was surprised to learn how rich my idle and how lean my carb at WOT was. This was with a brand new Holly 4160 that's supposed to be tuned for most applications out of the box. Yeah right!
Old Nov 15, 2010 | 01:56 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Autometer's website is pretty good and they have a WBO2 gauge in your series: Pro comp ultra-lite WBO2 I use google shopping to find the best price and Summit will match it.
I use an Innovate LC-1 gauge and it works well.
Don't get a narrow band O2 sensor unless you only want to tune idle and cruise.
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
