mild cam on stock block?
i have a 86 5.0 chevy block with stock internals and 601 chevy heads.
here are the specs:
14022601 267, 305 HO, 80-85, 58cc, 1.84-1.5, 7 bolt ex.
and i want it to sound a bit rough so ima install a cam. will this cam work with this head?
here is the cam
http://www.summitracing.com/parts/SUM-1065/
here are the specs:
here is the cam
Re: mild cam on stock block?
"Work" and "run good" are 2 very different things.
Instead of that, if you're just dying to swap a cam for some reason, use this one instead.
http://www.summitracing.com/parts/CCA-CL12-234-2/
It's a KNOWN GOOD match for that motor in otherwise stock condition: will in fact actually make the car faster, instead of slowing it down.
I'd STRONGLY recommend replacing the valve springs with the cam mfr's recommendation at thte same time.
