Not typical A/C system in defrost mode
Old Nov 17, 2010 | 08:03 AM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
Ok, I think I have read just about all the posts for this problem and I cannot figure out what the problem is. Vacuum ball is mounted and functioning. 2 years ago, I replaced the vacuum hose that runs from the check valve at the intake manifold to the vacuum tank and the vacuum selector valve (the disc that changes where the vacuum is routed behind the control panel). All the hoses are connected in the engine bay where they are supposed to. I do not hear any vacuum leaks at the control panel or in the engine bay (although even with a hose to listen for leaks, the noise from the engine is loud.)
I do have a FSM and that has helped me to understand more about the system. The only checks they request you do is “check for faulty components.” Before I start taking pieces off and checking, I am wondering if anyone has any suggestions.
I know I have to be losing vacuum somewhere (I could not hear a leak) or the vacuum that I am getting is not enough to power the system. Does anyone know how much vacuum I am supposed to be getting off the intake to power the system?
Old Nov 17, 2010 | 08:37 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Not typical A/C system in defrost mode
Test it with a hand vacuum pump with the engine off.
Old Nov 17, 2010 | 09:19 AM
hot92RS's Avatar
Car: 92 Z-28
PepBoys has a vacuum pump for about $35.00. That would allow me to hear better any leaks not having to run the motor for sure but will it be able to test how much vacuum is coming off the intake?
Old Nov 17, 2010 | 09:42 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The amount of vacuum in the intake is "lots". It's not a variable here.
Old Nov 17, 2010 | 10:38 AM
hot92RS's Avatar
Car: 92 Z-28
How do I make sure that I have the proper vacuum for the lines that run the HVAC system controls?
Old Nov 17, 2010 | 10:40 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'm not sure what you mean. If the engine runs, it produces enough vacuum.
gta892000
Sep 16, 2015 12:37 AM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
adelane
Sep 9, 2015 08:51 PM
scottmoyer
Sep 7, 2015 07:06 PM
Slush92RS
Sep 2, 2015 08:56 PM
