How far does the harmonic balancer sit from the timing cover?
Old Nov 19, 2010 | 10:17 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey guys, I have a 1978 350, 2 bolt main, with an 8" balancer.. How far should it sit out from the timing cover? The bolt is torqued at 60 ft/lbs and sits 3/8" from the cover, is this too much?
Old Nov 19, 2010 | 06:03 PM
Damon's Avatar
Re: How far does the harmonic balancer sit from the timing cover?
Sounds about right.
Old Nov 19, 2010 | 09:27 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Should be close, but should bottom out when you are using an installer on it anyway. Then install the bolt and torque to specs.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
86White_T/A305
Aug 17, 2015 12:16 AM
