set around
Old Nov 20, 2010 | 11:58 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
set around
bought a 89 iroc-z that didn't get used much for 4 years before I bought it,I've replaced the front calipers and flex lines.repared some wires,Mice damage.Havn't run a full tank of fule through her yet.Previouse owner said it had fresh fuel in it,It's starting to backfire some out the exsaust and stinks like yek.I have put stabil and injector cleaner into the tank.fixing to add 15 gal of fresh fuel,any comments before I start her up again.I don't want to mess this motor or injectors up.
Old Nov 21, 2010 | 12:32 AM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: set around
i dont think it'd hurt to run some seafoam through her just for the sake of the matter, i wouldnt go to hardcore on the fuel treatments just because ive heard some horror stories about it eating up fuel lines. worse case case scenario would be pull tank clean it out if you can fit your arm through the opening. and purge the lines you'd be good to go from there. go luck to you ill keep an eye out for a follow up let me know how it goes.
Old Nov 21, 2010 | 12:50 AM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: set around
Check the fuel filter a few times to make sure there isn't a bunch of junk in the tank.
Old Nov 21, 2010 | 09:48 AM
speedlimit96's Avatar
Car: 92 25th anniversary z28!!
Engine: 5.7L 350
Transmission: 700R
Axle/Gears: stock
Re: set around
i would do a full tune up on it, spark plugs, fuel filter, fuel injectors, new coolant, new oil, new tranny fluid and filter, drain your rearend and new gear oil, all the goods, a car sitting that long will need a full tune up.
Old Nov 21, 2010 | 03:49 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: set around
couldnt agree more this is your best bet then you've covered all your fluids and will be able to rule any of that out if there are any problems that arise.
Old Nov 21, 2010 | 11:34 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: set around
ok,I think they may have done the spark plugs and wires but know they did't do the oil and filters,the tranny is having trouble in 3 and 4,talking to a member in kentucky about a 91 tranny for a fair price,you think fluid and filter might help a tranny that drops out after leaving second gear into nothingness?On your say so I will give it a try.cross your fingers.
Old Nov 21, 2010 | 11:36 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: set around
whats sea foam
Old Nov 22, 2010 | 07:54 AM
southbay08's Avatar
Re: set around
Seafoam is a great product... It is multi-use motor treatment.
It is an:
injector cleaner
carburetor cleaner
carbon cleaner
fuel stabilizer
frees lifters-rings
de-icer anti gel
upper cylinder lube
dries oil and fuel.
Old Nov 22, 2010 | 05:30 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: set around
dude mine did the same thing! i literally just swapped my tranny saturday if someone has an idea of how to fix this im gonna be mad haha but hopefully for you i hope so, i know my tranny had awful looking tranny fluid and not really a lot of it, i bought a used 7004r and im thinking it has a shift kit but im not getting any answers on the forum about it, fyi a dry tranny cost about $70 in fluid filter and seals a 700r4 takes 11.2 qts dry.
82tabird
Dec 21, 2015 10:22 PM
lt1z350
Sep 29, 2015 01:50 PM
hydrolic144
Aug 29, 2015 04:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
