motor almost dies after hard acceleration then clears up
Old Nov 27, 2010 | 09:43 PM
ncracer409's Avatar
I have a 86 camaro i did a 350 swap 1979 350 block bored 40 over with a crane 284 energizer cam vortec heads wiened stealth intake accel dist,wires, and plugs headers holley 670 street avenger carb car runs great if it is driven normal but if i shift through all gears under hard acceleration and let off the motor wont take any gas it almost dies runs like crap than clears up and runs great im stumped please help thanks
Old Nov 27, 2010 | 10:27 PM
belowfire's Avatar
Car: 1986 firebird trans am
Engine: Crate 350 4bbl holly carb
Transmission: turbo 350
Axle/Gears: moser 12 bolt 4.55 posi
Re: motor almost dies after hard acceleration then clears up
Sounds like air restriction try it with no hood on see what's happens if it keeps happening then mite be fuel supply issues
Old Nov 27, 2010 | 11:43 PM
ncracer409's Avatar
What should fuel pressure be at?
Old Nov 28, 2010 | 01:11 PM
belowfire's Avatar
It depends on your Carb look it up on Holley website if you have have the right fuel output now turn in up skittles see what happens
mustangman65_79
Apr 14, 2017 05:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
db057
Aug 22, 2015 08:17 PM
cstrobel65
Aug 15, 2015 10:19 AM
