where does this tube connect to?
Old Nov 27, 2010 | 09:51 PM
Moe87's Avatar
IS this line connected to the brake booster?
Old Nov 27, 2010 | 10:01 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: where does this tube connect to?
No, it runs from your Cruise control diaphragm along the framerail, through the firewall, and hooks up to a switch mounted on your brake pedal.
Old Nov 27, 2010 | 10:02 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
That is cruise control
No vac lines connect to booster.
One should go to intake vac , the other should go through the firewall to switch on brake pedal
Old Nov 27, 2010 | 10:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Except for the 3/8" one.
Old Nov 28, 2010 | 05:39 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Obviously
I was referencing the pic he had up
Old Nov 28, 2010 | 05:54 AM
mightymaro94's Avatar
x3
Old Nov 28, 2010 | 12:04 PM
Moe87's Avatar
right i was aware of the other connections to the cruise and not that. Is there a need to plug the thicker tube to prevent anything or leave it open?
Old Nov 28, 2010 | 02:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Are you disabling your cruise?
Old Nov 28, 2010 | 04:04 PM
Moe87's Avatar
yes. ive removed the cruise control tv cable to the TB, ive ran a hose directly from the vacuum tank under the battery to the T connector area near the distributor and i've temporarily caulked the tube this thread was about shut. obviously the cruise control mechanism has been unplugged and unbolted from the fender/body and removed.
Old Nov 28, 2010 | 04:53 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by Moe87
ive ran a hose directly from the vacuum tank under the battery to the T connector area near the distributor and i've temporarily caulked the tube this thread was about shut. .
If you have no vac from intake going to cruise unit then you don't need to plug / disconnect anything else
z 28 jari
Sep 14, 2021 10:03 PM
b4ccamaro
Jun 5, 2016 01:48 PM
75bike
Sep 20, 2015 09:37 PM
BOOT77
Sep 16, 2015 08:37 PM
gta892000
Sep 16, 2015 12:37 AM
