Tranny Flsuh
Old Nov 28, 2010 | 07:16 PM
native1031's Avatar
Tranny Flsuh
How hard would it be to do a tranny flush myself? And if possible a quick lesson on how to do it. Thanks
Fairly certain its a 700r4 trans
Old Nov 28, 2010 | 08:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
1. Drain the transmission by dropping the pan.
2. Replace the transmission filter.
3. Reinstall the pan with a new gasket and add as much ATF as you drained. Don't start the engine yet.
4. Disconnect a cooler line. Use a rubber hose or something to route the flow into a jug (at least a gallon).
5. Be ready to add fluid (funnel, ATF, etc.). Start the engine. Add fresh fluid as the old stuff is pumped out of the cooler line.
6. When the fluid being pumped out looks fresh, or you've pumped out about a gallon (and added that much as it was being pumped out), shut off the engine.
7. Reconnect the cooler line. Start the engine and check the level. You should have the transmission warmed up before you fill it up to the "Full" mark.
Old Nov 28, 2010 | 09:29 PM
native1031's Avatar
Re: Tranny Flsuh
Thanks that sounds pretty simple and basic
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
