BBK fuel pressure regulator
Old Nov 28, 2010 | 11:56 PM
tpiirocz's Avatar
Car: 89 CAMARO IROCZ
Engine: 5.7 TPI
I have a BBK adjustable fuel pressure regulator and with the slp siamese runners the plenum hits the adjusting screw. So to adjust the fuel pressure i have to unbolt the plenum. Has anyone had this problem? And if so is there an easy fix? Or is it as easy to fix as putting a shorter adjusting screw in.
Old Nov 29, 2010 | 12:18 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: BBK fuel pressure regulator
Shorter bolt should work as long as your FP is at the right pressure.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
