Steering wheel/Ignition/Cruise control Wiring help!
Old Dec 1, 2010 | 05:17 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Im swaping out my old steering column, mine originally had cruise control, but the replacement doesnt. There is what looks to be a vacuum hose? going from the firewall to a circuit attached to my brake pedal. Im assuming this is the release for the cruise control. But again, my replacement doesnt have cruise, is there a way to take that line off? and what do all these wires go to?
Attached Thumbnails Steering wheel/Ignition/Cruise control Wiring help!-100media_imag0018.jpg
Old Dec 1, 2010 | 05:22 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Re: Steering wheel/Ignition/Cruise control Wiring help!
What does that metal rod do? and i witched the ignition switch from my old one to my new one, because i didnt have a key to the replacement. Will that still work? Thanks -Matt
Old Dec 1, 2010 | 05:23 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Forgot the pic in the last post
Attached Thumbnails Steering wheel/Ignition/Cruise control Wiring help!-100media_imag0018111.jpg
Old Dec 3, 2010 | 03:09 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
I could really use some help, i need this car for work. and now when i turn the key the lights dont come on until the key is turned all the way, and the car doesnt crank or anything. i think theres something wrong with either the wiring or the ignition cylinder was installed wrong. when putting the lock plate back on in the steerring wheel, does it matter how it is put back on?
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Bull86
Aug 10, 2015 05:43 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
