91 camaro not firing
Old Dec 2, 2010 | 06:50 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
the car was running and then stopped one day and i did a little research and heard the ignition modules go out all the time so i went ahead and replaced the whole distributor. re timed the car best i could. tdc and everything lined up pretty close. distributer right with the rotor on number one on the cap.. i dont have the viec label or watever it was. i have it at 6degrees right now. so replaced the distributor..car cranks and fires real quick but not enough to start. im not sure why. if it is timing why it sounds like it so far off. ive heard lose timing chain. can it be anything else?
Old Dec 3, 2010 | 12:26 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: 91 camaro not firing
Try a re-do on your timing. Sounds like it may be firing on a few cylinders but not enough to keep running. Crank while adjusting dist position SLIGHTLY in either direction and see if it will catch. Once there, then fine tune timing to 6* and see if it continues to run.
Old Dec 3, 2010 | 08:09 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Did you check to make sure it's getting enough fuel?
92camaroJoe
Jul 29, 2023 07:57 PM
mdtoren
Aug 23, 2015 12:52 PM
TheExaminer
Aug 19, 2015 10:07 PM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
