Head gasket and pushrod question
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
The engine is a roller cam engine pulled from an 89 formula. Stock cam. I've done some searching and come up with 7.200 being the correct pushrod length. Checked jegs and came up with this
http://www.jegs.com/i/Lunati/638/82720-1/10002/-1
I just want to make sure this is correct since that's actually cheaper than stock.
Also, I'm doing a head swap next weekend going from the stock L98 head(64cc?) to a 67cc World S/R head. What size head gasket would be best used here?
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Head gasket and pushrod question
Best idea would be to do the felt tip marker job on the valve stem with an adjustable measuring push rod. Then you're sure of the length.
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
I'm getting confused on finding the stock pushrod length. Everything I'm reading here is saying 7.200 but all parts stores in my area sell 7.192.
ambainb
Apr 25, 2016 09:21 PM
NinjaNife
Aug 23, 2015 11:49 AM
