External inline Pump not pulling fuel...reasons?
Old Dec 6, 2010 | 09:21 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
84 T/A, carbed with inline Holley electric pump replacing the mechanical engine mounted one (New 350 has no provision for mechanical pump). It's not pulling fuel from the tank. I can hear it running, but it's not drawing fuel. I pulled the fuel lines and blew air through both feed and return lines and both are clear (Well, I hear bubbles in the tank and feel air coming out of the filler neck). I suppose that the sump inside the tank is too clogged to pull fuel but also let air back through? I'm just looking for ideas on what this could be.
Old Dec 6, 2010 | 09:28 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: External inline Pump not pulling fuel...reasons?
Where did you mount the pump? Is it wired backwards?
Old Dec 6, 2010 | 09:55 AM
Ozz1967's Avatar
Car: 1984 Trans Am
I mounted the pump behind the rear seat, bolted to the sheet metal (makes it kind of loud in the car unfortunately). It's not wired backwards, it worked great for 4 months.
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
spaigo
Aug 21, 2015 07:46 PM
formula_novice
Aug 18, 2015 08:48 PM
