really strange idle
Old Dec 10, 2010 | 01:26 PM
scarr001's Avatar
Car: 92 camaro rs anniversary edition
Engine: v8 5.0 Tbi
really strange idle
So, if anyone knows what the timing should b on a 92 v8 350 camaro that will help...when my car is in idle- it "Chugs" idle, idle idle then chug then idle idle chug....any ideas? It doesn't die- and we have done a timing light so we know that's right
Old Dec 10, 2010 | 03:42 PM
scarr001's Avatar
Engine: v8 5.0 Tbi
Re: really strange idle
So we narrowed it down to a vac leak, can anyone give me an idea what it costs to repair something like that?
Old Dec 11, 2010 | 07:14 AM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Depends on where the vacuum leak is. Start with the easy stuff first. Some guys will advise spraying carb cleaner on all of the vacuum line connectors. When the engine revs, you've found your leak. Never really worked for me. Vacuum line is relatively cheap and sold at any auto parts store. They need to be replaced from time to time anyway since they get brittle and crack. Don't forget the pcv valve when you start the project. It can cause a low vacuum issue.
86IROC112
Nov 27, 2015 09:54 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
