86 Iroc 305 TPI sensor, help!
Old Dec 11, 2010 | 02:36 PM
baladairsupply's Avatar
I am having issue's identifying what the sensor is on the drivers side of the block between the first two cylinders. Also, advice on a GOOD repair manual and where to pick one up would great.
Old Dec 11, 2010 | 03:12 PM
turbinator3's Avatar
Re: 86 Iroc 305 TPI sensor, help!
that is engine temp sensor. does it have a single wire going to it?
Old Dec 11, 2010 | 04:25 PM
yes, only one wire. I am having a problem with my temp guage reading. I have two sensors on the front of the engine. I replaced one that I thought was the temperature sensor but maybe this newly discovered one is my problem.
Old Dec 11, 2010 | 11:47 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello baladairsupply!!
The sensor in the driver's side cylinder head is the temp sensor for the gauge, usually has a single green wire!!
P.S. If the wire is not connected, your gauge won't work at all, if it's grounding out it will usually read high really quickly, if it's an intermittent connection, it will usually react slowly!!
Once you get the connection fixed, the sensor changed/checks out, and the wire checks out okay, if your still having problems, I would make sure that your gauge in the dash is held tightly with the screws, and not just sitting there, loose, like mine was!!
Old Dec 12, 2010 | 01:05 AM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
Here is the ultimate service manual, I have one for my 91. http://www.helminc.com/helm/product2...886&itemtype=B
Old Dec 12, 2010 | 01:12 AM
Hello Dartht33bagger!!
Using the trump card!!!!
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
