can you tell me what this is? ( pics )
Old Dec 11, 2010 | 06:16 PM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
Hello
how are you
i have one question: can you tell me what this is exactly i have an idea what that could be but i want to make sure i'm right im new to these engines .
thank you for you help and here are some pics.
L69
Old Dec 11, 2010 | 06:27 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: can you tell me what this is? ( pics )
I believe that would be your coolant temp sensor.
Old Dec 11, 2010 | 06:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Old Dec 11, 2010 | 10:28 PM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
Thanks a lot guys i knew i could count on you
Old Dec 11, 2010 | 11:20 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello Electro_X!!
You might want to fix the wires going into that connector, they seem to be exposed (bare wire) !!
Old Dec 11, 2010 | 11:33 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
Bythe picture, it has to be an 82 to 84 Trans Am.
(real cowl induction from the hood)
It is a temp sensor, but which one?
Those years used a temp sensor for the gauge
and a separate one for the ECM.
You can buy the connector from the dealer and splice the wires together.
In the interim you really need to tape those wires up
Old Dec 11, 2010 | 11:59 PM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
Originally Posted by 87IROC-DAN61
Hello Electro_X!!
Yes that's why i wanted to know what it is, so i can buy new one and fix it. and
yeah it's 84 trans am recaro with real cowl induction from the hood.
aha there you go i didn't realize i can just buy the connector , so i actually don't need the sensor just the connector.
thanks for brining this into my mind
Old Dec 12, 2010 | 12:23 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Pictured is the ECM sensor. The gauge sender is in the driver side head in all years.
Old Dec 12, 2010 | 12:35 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
1-wire sensor is for gauge and would be on the head not the intake.
2-wire sensor is for ECM.
Old Dec 12, 2010 | 12:57 AM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
did not know that looks like i learned something
Old Mar 28, 2011 | 11:17 PM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
hi guys so today i finally got to change my CST and it works great
here is some pic to look at
Old Mar 29, 2011 | 11:44 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
When you get a chance, solder and heat shrink those splices. The clip on splices you used will invite corrosion which will alter the signal from the CTS. If you aren't comfortable with solder, use heat shrink butt connectors and a good set of crimpers, such as Klein. You should use a heat gun to shrink and seal the tubing but you can get by with a BIC lighter in a pinch if your careful.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
