Need Advice ..Steering pump ?
Old Dec 12, 2010 | 02:31 PM
mtlgta's Avatar
Car: 89 GTA
Engine: 350 5.7
Hi , I own a 89 GTA 350 . Came back from a 800mile trip and noticed when I was going 70 or more there was a whinning sound coming from the engine bay and a burning smell .I pulled over poped the hood the sound was gone but the burning smell was there . I limped the car home going 50 mph. At 50mph there was no noise or smell .This morning I removed the belt checked the smog pump it was spinning freely as was the AC . Then I checked the steering pump for fluids it was bone dry ( I have no idea how long I have been driving it with out oil) I filled it with oil went for a ride it still whines but no smell . I am not a mecanic need some advice do I change the pump or could it be something else I over looked .
I need to get it fixed so I can go home for the holidays .
Thanks In Advance
Steve
Old Dec 12, 2010 | 04:58 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Need Advice ..Steering pump ?
Repair the leak and give it a little time. If it's still whining after a few days it may be time to replace it.
Old Dec 13, 2010 | 02:06 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I would say repair the leak, which is probably your hoses, and replace the pump since you obviously ran it dry for some time. Replacing it now would be the more proactive thing to do.
Old Dec 13, 2010 | 07:59 PM
mtlgta's Avatar
Car: 89 GTA
Engine: 350 5.7
Thanks Naf
Old Dec 13, 2010 | 08:03 PM
mtlgta's Avatar
Car: 89 GTA
Engine: 350 5.7
Thanks ASE doc. I was thinking of changing the hoses and pump ,would you happen to know what a shop would charge ?
Old Dec 17, 2010 | 06:29 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Mitchell shows 2.9 hours for the pump and hoses. I would think a good tech could do the job in 1.5. What you're charged will depend on how reasonable the shop is. The only special tool required is the pulley removal/installation tool. That and perhaps flair wrenches. It is not a high skill job, probably level B.
theshackle
Mar 5, 2017 06:37 PM
stalkier
Aug 21, 2015 01:54 AM
justin57
Aug 20, 2015 07:05 PM
formula_novice
Aug 18, 2015 08:48 PM
Newguy91rs
Aug 7, 2015 09:51 PM
