89 firebird 2.8l won't start help please!!!
Car: '89 Firebird
Engine: V6 2.8
Transmission: 5SP
hello everyone,
Hope someone can help with this. i am completely confused. i just picked this car up a week ago not running. but has potential i hope....lol the guy i got it from said he thought it needed a fuel pump. i found the pressure check point on the fuel rail. had my friend open it while i turned the key. it shot out like old faithful. so i am guessing the pump is good. i don't have a guage to find out the exact pressure. it turns over but not spark. got a new coil my friend hooked it up without taking the old one off and there is still no spark. not sure what to do. any ideas guys or if somebody has had this problem and how to fix. my first firebird was a 85 305ci didn't have all the electronic do-dads....lol
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
Re: 89 firebird 2.8l won't start help please!!!
module in the distributor?
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Several auto parts stores have tester and will do it for free. Where and how are you checking for spark? Ignition module is often the most likely suspect. Get that checked first. Call first and see if they can do it for you
Car: '89 Firebird
Engine: V6 2.8
Transmission: 5SP
Thanks guys!!!! It was the ignition control module. I glad it was that easy. now gotta get tabs and i am on the road. to see it is worth it to trick out.....lol
thanks again for the help with my problem.
Habe a great day.
Habe a great day.
theshackle
Mar 5, 2017 06:37 PM
