Engine Specs, looking for help
Car: 92 Camaro RS
Engine: 5.0 TBI
Transmission: 5 speed Manual
Axle/Gears: Stock 3.08
Hello all. I'm sure these questions have been asked a hundred or more times on here, but I cant seem to find the answers. Does anyone out there know what the stock valve-to-piston clearance is on an LO3 engine? Also, what the stock cam lift is on both Intake and Exhaust? I'm starting an engine build on my 92 (yes, building the 305. Why? Because no one else does!) and I'm looking for some baseline specs before I get too worried about cam profiling and head work. I'm sure I could find this info in some of those old books, but figured I'd start with you all first. Thanks for any help you may have!
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Engine Specs, looking for help
Stock P-t-V clearance is huge. LO3 valve lift is .350/.384
Car: 92 Camaro RS
Engine: 5.0 TBI
Wow, I did not know that. I guess I have lots of room to work with. Thanks for the info!
