Quick Quench Question
Old Dec 20, 2010 | 10:07 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Let me run this by you guys just to re-assure myself...
If the "quench area" is the tight area between the flat portion of the piston and the flat portion of the combustion chamber in a typical wedge-style chamber....
My thinking is, it should make no difference if
A) The block is Zero decked (Piston is flush with the deck at TDC) and you run a .040" head gasket
VS
B) A Piston .025" in the bore with a .015 head gasket....
Both have a quench of .040"
Same desired effect, RIGHT?
Old Dec 20, 2010 | 10:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Quick Quench Question
Essentially
355tpipickup
Aug 27, 2015 08:13 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
