Hmm.. weird feeling at 50+mph..
Old Dec 22, 2010 | 11:41 PM
89IROCZ-28's Avatar
Car: 1989 IROC Z28
Engine: 350 (5.7 TPI)
Transmission: Automatic
Axle/Gears: 2.73 (Stock)
Well, today I got my exhaust finally replaced.. Y-Pipe back.. 3Inch into a Magnaflow dual.. however.. still have this weird feeling (seems like its out of the passanger side head) almost like a clicking or tapping noise. I don't suspect its the typical injector noise.. it sounds like the rollers aren't right and its causing a weird viberation.. anyone have any idea? I know the fuel filter needs to be changed badly.. (orginal 89..AC delco lol) and of course.. when I take it to a shop no one can hear the noise but me =\
Old Dec 23, 2010 | 04:01 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Hmm.. weird feeling at 50+mph..
Are you seriously running the original fuel filter? Get on top of your maintenance before you start looking for the cause of a probelm.
Old Dec 23, 2010 | 04:05 PM
stroken85z's Avatar
Car: 1985 Z28/1981 Z28
Engine: 85 383 stroker/81 350
Transmission: 85 fortes tko 600 /81 turbo 350
Axle/Gears: G P ford 9" in proces
i didnt know fuel filters lasted 20 years and just think of all the money ive been wasting on them
Old Dec 23, 2010 | 10:00 PM
89IROCZ-28's Avatar
Car: 1989 IROC Z28
I just got the car, and yes its the orginal fuel filter, he had the orginal air filters, and still the orginal shocks\struts.. rofl. I had the engine fully rebuilt, and I'm trying VERY hard to get the fuel line to gently break free.. its heavly rusted on the passenger side of the filter(the one near the tire I can freely losen) I can't afford to snap a fuel line.. not sure if you guys have checked recently.. but you can't really find them anywhere. >.>!
Old Dec 27, 2010 | 06:14 AM
chrisfrost's Avatar
I would imagine You're gears are 3.42 which are the stock Z-28 and iroc gears . With a 700 r-4 tranny and 2.73 You would be on the highway at 80 mph the engine would be turning about 1800 rpm locked up in 4th gear . The fuel line is just steel tubing bent to fit . If it's rusted n that old it might be a good idea to replace it anyway , You guys do have a little snow up there . Not as much as say Groom Creek , but enough . Good luck
Old Dec 27, 2010 | 11:56 AM
ZZsmpch's Avatar
Soak everything in PB Blaster or something before trying to break it loose. I agree, replace the lines if they are rusted.
Old Jan 4, 2011 | 03:11 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
The TC clutch engages at about 45mph in OD. With the converter locked, any roughness in the engine is transmitted directly to the drivetrain, making it much more noticable. Even with a good running engine, many people notice some harshness as the drivetrain becomes solidly connected to the motor.
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
gord327
Sep 29, 2015 10:18 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
