LO3 305 to L31 350 swap parts list. Did I miss anything?
Old Dec 26, 2010 | 05:01 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
I will be camming the motor as well, so those bits and pieces are included.
FIREBIRD: GUTS LIST
Water pump $37
http://www.autozone.com/autozone/parts/Valucraft-New-Water-Pump/1996-Chevrolet-C1500-1-2ton-P-U-2WD/_/N-j5co3Z9pd8f?counter=1&itemIdentifier=826644_176315_0_
Head Gasket (purchase 2) $30
http://www.summitracing.com/parts/FEL-7733PT2/
Intake Manifold Gaskets $24
http://www.autozone.com/autozone/parts/Felpro-Intake-Manifold-Gasket/1996-Chevrolet-C1500-1-2ton-P-U-2WD/_/N-j5co3Z93xym?counter=5&filterByKeyWord=intake+manifold+gasket&fromString=search&itemIdentifier=579207_29647_5297_&sortType=low
Flywheel $88
http://www.summitracing.com/parts/ZZZ-50-6527/
Clutch Kit $100
http://www.summitracing.com/parts/ZZZ-MU56-1/
Intake Manifold $156
http://www.summitracing.com/parts/PFS-52028/
Camshaft $226
http://www.summitracing.com/parts/NAL-24502586/
or
http://www.willhoitescams.com/ ($130)
Timing Set $27
http://www.summitracing.com/parts/SUM-G6503/
Timing Cover $26
http://www.summitracing.com/parts/NAL-12562818/
Timing Cover Gasket Set $8
http://www.summitracing.com/parts/MIL-65503/
Oil Filter Adapter $20
http://www.summitracing.com/parts/SES-3-60-08-900/?rtype=10
Spring Kit $89
http://www.alexsparts.com/products/VALVE-SPRING-KIT%2C-SB-CHEVY-VORTEC%2C-HI%252dPERF-HYD-ROLLER-%26-MECHANICAL-FLAT-TAPPET.html
Valve Seals $16
http://www.alexsparts.com/products/UMBRELLA-SEALS%2C-SB-CHEVY%2C-VITON.html
TOTAL PRICE: $770 - 860
of course this is not accounting for the ~$100 in hoses and other bits and pieces. Already have poly motor mounts waiting to go in.
Old Dec 31, 2010 | 01:17 AM
Grumbles's Avatar
Re: LO3 305 to L31 350 swap parts list. Did I miss anything?
Bumpedy bump. Any advice much appreciated!
Old Feb 25, 2011 | 04:33 PM
cmnewark's Avatar
Car: 1989 RS,
Engine: 305 TBI....for now
Transmission: T-5.... for now
Axle/Gears: '89 3.73
Looks like a good list. Let me know how it goes, I'm looking at doing a similar swap into a 89 RS. I'm going with the GMPP 12496821 manifold though for the EGR.
GL!!
Old Feb 25, 2011 | 09:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
What front accessory drive system are you using?
Need a water pump that will fit / suit your car ; not the engine
Truck pumps tend to be long ones / car pumps are generally short style
Old Mar 16, 2011 | 12:23 AM
mikesanto70's Avatar
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
You cant just drop that thing in behind the 700R4 since its a TBI already. What is the least amount of swap parts that I need to go in place of the L03, and use the stock 700R4. I'm looking for the least painful/expesive way to be able to lay rubber w/ my right foot, also putting a rear end from 02'Z28 w/ 3:42's, should be healthy since my brothers 1996 single cab 2wd stepside 5.7 L03 w/ 3:73's was a beast, I mean quick, it used to hang w/ my 85' TPI Vette to 100mph.
Old Mar 16, 2011 | 12:26 AM
Engine: L99 L98
Correction, typo, my brothers chevy was a L31, accidently put L03, but it was insane for the day back in 96' when it was new, just a cat-back and a K&N
Old Mar 16, 2011 | 01:29 AM
Engine: L99 L98
where in AZ are you from?
Old Mar 16, 2011 | 06:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Why are you getting the head gaskets and oil filter adapter?
Old Mar 17, 2011 | 06:43 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Here is a great sticky tread from the TBI forum, with all details https://www.thirdgen.org/forums/tbi/...i-buildup.html
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
1nastygta
Aug 8, 2015 07:38 PM
gwade12
Aug 8, 2015 08:17 AM
