Just bought an 86 Iroc
Car: 1986 Camaro Iroc Z
Engine: 5.7L Corvette L98
Axle/Gears: 2.73 Open
Hello,
I just bought an 86 Iroc. On the 100 mile ride home I realized this car has a few issues that need to be worked out. The engine supposedly has been swapped from the original 305 to a TPI 350 out of a vette. The trans is the original 700R4 which feels like it is slipping in between gears. I jumped on it on the highway a little and the shift points are all messed up and I am not sure why. I was under the impression TPI motors shift somewhere between 4500-5500, but this one is not shift at WOT till around 6800RPM. I really don't know why to be honest and was wondering how I could adjust this? I am hoping the "kid" I bought this from hasn't been flooring it ever where he goes. Trans also feels like it grabs good in between gears, but shifts are extremely long and slopy. Is this normal for these cars?
Dan
Dan
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Just bought an 86 Iroc
It's not shifting at 6800 RPMs. Your tach is off, which is pretty common.
For TV cable adjustment and other general info on your trans, try:
http://www.tvmadeez.com/
Yea, I put some more miles on it today... I have had other 350 cars and it doesn't sound like its shifting that high. To make your case, I found the original 85 MPH gauge cluster in the trunk. Any articles on how to calibrate the tachometer or what to do with it?
Dan
Dan
And one more thing I forgot to mention. Any way to correct the huge shifting lag from gear to gear? It lags in every gear.
DG
DG
There's something here somewhere on tach fixes.
Slow shifts could be as simple as low fluid or as dire as a rebuild. Post up in the trans section with some specifics. There are more experienced guys than me on trans.
ambainb
Apr 25, 2016 09:21 PM
86IROC112
Sep 7, 2015 01:37 PM
mustangman65_79
Aug 11, 2015 03:17 PM
