Best Heads For My 305 TPI.
Old Jan 1, 2011 | 09:57 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
hello, Id like to know what are the best aluminum heads would be for my 305. I have a TPI 305 LB9. It has the original heads on it. I am keeping the factory cam and factory lifters I dont want to change this. I would like to put a high flow set of heads on it and some roller rockers and thats it. Maybe leave room for the high flow Edelbrock TPI setup down the road. So what are the best heads to get so it will work with my computer and stock set up and improve performance. As far as chamber size and port size if people can tell me some more about that. thanks everyone
Old Jan 1, 2011 | 03:16 PM
IAGTA's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 w/SLP cold air intake
Axle/Gears: 9 Bolt 3.27 with PBR brake upgrade
Re: Best Heads For My 305 TPI.
The World Products SR Torquer 305 heads are a direct interchange. You will need a head with the small chamber size found on the 305 (I think it's 57cc) or you will lose ground due to a lower compression ratio. Good Luck!
Jake_92RS
Jan 28, 2020 10:37 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
marcusaw
Aug 10, 2015 08:13 AM
