high rev startup
Old Jan 1, 2011 | 02:27 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
high rev startup
Hey guys, havnt started my iroc for a while now bacuse its winter. I took the intake off and painted it, and put everything back together the way it was before. Now today i went to start it because it was *warm* or 8degrees. as soon as it started it reved up high, so I shut it off immediately. I tried a few times, but it reved every time. Could it be reving because it cold and starting up, or would it be an air leak?
Old Jan 1, 2011 | 02:34 PM
travis_henry's Avatar
Car: stock car
Engine: 350 Chevy
Transmission: 1.76 powerglide
Axle/Gears: 3.73s
Re: high rev startup
How high did it rev to? and prolly a vac leak.
Old Jan 1, 2011 | 02:40 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
I killed it once it reached about 4000, and the tach stayed there once I shut it off
Old Jan 1, 2011 | 03:07 PM
Car: stock car
Engine: 350 Chevy
Axle/Gears: 3.73s
oh yeah man thats a major vaccum leak. did you hook back up the brake booster line?
Old Jan 1, 2011 | 03:13 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Yes sir.
Old Jan 1, 2011 | 03:15 PM
Car: stock car
Engine: 350 Chevy
Axle/Gears: 3.73s
Is the throttle hung on somthing maybe ??? cause 4000 rpm is way high for not pushing the gas down even if it has little leaks it shouldnt rev that high. I would check the throttle cable.
Old Jan 1, 2011 | 03:20 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
I have the *ram air* air dam box and tube off so I can see the throttle body, and it is closed. I found a a/c hose disconnected, but I doubt thats it.
Old Jan 1, 2011 | 03:29 PM
Car: stock car
Engine: 350 Chevy
Axle/Gears: 3.73s
Damn man its got to be a major vaccum leak somewhere. its prolly a dumb question but did you use new gaskest when u put the intake back together? Make sure all of them are aligned correctly none of them are broke anywhere ect. 4000 is way high without giving it any throttle.
Old Jan 1, 2011 | 03:32 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
No I didnt use new gaskets, I just took of the plenum and runners and the gaskets were in good shape. They are all lined up right too.
Old Jan 1, 2011 | 03:37 PM
Car: stock car
Engine: 350 Chevy
Axle/Gears: 3.73s
Well if it went from running good to reving to 4000 rpm and all you did was take the intake off and use the old gaskets i would bet a gasket either got torn somwhere or somthing went wrong when putting it back on. all the vaccum lines on the throttle body are hooked up?
Old Jan 1, 2011 | 03:44 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Yes, the throttle body never came out or had anything disconnected, other then from the plenum.
Old Jan 1, 2011 | 03:50 PM
Car: stock car
Engine: 350 Chevy
Axle/Gears: 3.73s
Well for starter i would go over everything you took apart and make sure all the gaskets are sealing right.
Old Jan 1, 2011 | 04:05 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
I found a hose that goes to the little black box with GM on it and a green connector for the wires going into in, the hose that goes from the box to the plenum was slightly kinked. would that make a difference?
Old Jan 1, 2011 | 04:09 PM
Car: stock car
Engine: 350 Chevy
Axle/Gears: 3.73s
If it was kinked i dont think it would make it rev high but it might not run right are you talking about the map sensor?
Old Jan 1, 2011 | 04:10 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
yes, thats the one, forgot the name.
Old Jan 1, 2011 | 04:47 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
I managed to bend my runners taking them off, thought i got them bent back because they lined up at the top, but there is a big gap on the bottom I just found.
Thanks for your help
Old Jan 1, 2011 | 04:54 PM
Car: stock car
Engine: 350 Chevy
Axle/Gears: 3.73s
oh yeah that will do it. and no problem man best of luck with it!
gta892000
Aug 11, 2019 11:16 AM
CatmanFS
Sep 19, 2015 09:00 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
