Help with Serpentine setup
Car: IrocZ
Transmission: automatic
I have a 1986 IrocZ with a 305 engine. I have sourced the serpentine brackets, pulleys and bolts from and 88 Camaro and thought I could just swap my alternator, smog pump, power steering and vintage air A/C straight across. But nothing fits. Do I have to buy all new /second hand accessories or is there a fix.
Please help as I am half way through a major vehicle rebuild.
Car: 1983 Z-28
Engine: 5.7 L
Re: Help with Serpentine setup
you will have to buy everything for an 88 camaro u would need a 88 camaro water pump also...
i did the same swap on my current engine rebuilt/project...if u have all the screws it should just bolt on...u r also gona have to modify the wires a little...
LT1Formula
Oct 8, 2015 08:34 PM
