starter help
Old Jan 7, 2011 | 09:55 PM
white04's Avatar
starter help
i have a 91 camaro rs with a 305 in it. i had problems with the starter and took the starter off and the guy i had bought it from had a 350 starter on it and come to find out the starter was hung in engage. so i went and got a 305 starter for it and brought it home and tried putting it on but it wont bolt up against the block without hitting the flywheel anybody ever had this problem before? or have any ideas of what could be wrong?
Old Jan 7, 2011 | 10:20 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: starter help
My best guess is it's the wrong starter.
Old Jan 7, 2011 | 10:22 PM
white04's Avatar
Re: starter help
they make different types of starters to fit a 305?
Old Jan 8, 2011 | 12:16 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: starter help
There are two different sizes of Chevy flywheels / flexplates ( 153 and 168 tooth ) and each has it own starter
Starter must match flexplate.
If 350 starter is identical type to your 305 one then you can just swap the end housing over to suit your car
Old Jan 8, 2011 | 02:42 AM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
Re: starter help
You may also need to shim the starter.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
