help fuel in oil lots
Old Jan 8, 2011 | 10:32 PM
whiteboycv67's Avatar
Car: 90 Firebid
Engine: 3.1
Axle/Gears: 10 bolt posi w/4.11s
anyone got any advice for stopping fuel in crankcase other than adjusting float in carb and putting new better plugs in ?? could it be the heads even tho i got 125 psi compression on all holes ?? if so how do i fix them ??
Old Jan 8, 2011 | 10:49 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Re: help fuel in oil lots
Well what type of Carb? My guess is that your fuel pump is bad. They usually have a visible leak when they start to go but I have seen them go bad and pump fuel into the crank case without leaking externally. I had a Holley on a car one time and it was dumping too much fuel so I rejetted it and the car ran better.
Old Jan 8, 2011 | 11:26 PM
Car: 90 Firebid
Engine: 3.1
its a rochester the fuel pump is electric now puttin out 5 psi im still workin on it tonight till i figure it out i have to have it back to the customer tomorrow is there anywhere in the head it could be gettin in like valve seats ?? or is that just oil into the cylinder ?
Old Jan 8, 2011 | 11:57 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Rings are really the only place it can get in if you dont have a mech. fuel pump. I would suspect an overly rich carb, excessive blow-by, or a bad ignition.
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
