MSD pro billet (TPI to Carb)
Old Jan 10, 2011 | 11:57 PM
Cody Ashby's Avatar
Car: 1991 Firebird Formula
Engine: 6.0 LQ4
Transmission: TKO600
Ive sold almost all my stuff from my TPI setup and im now going to carb. I was wondering if my MSD pro billet #8366 will work with the carb setup and everything? Thanks guys, link to distributor below
http://www.msdignition.com/product.a...365&terms=8366
Old Jan 11, 2011 | 12:33 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: MSD pro billet (TPI to Carb)
Unless you intend on using the computer for spark control only, that one wont work, as it requires the ECM for control. You need a standard non computer controlled HEI distributer if your ditching the TPI and ECM.
Edit: it looks like you already have the dist. If you do try to run it, the dist. will give very little advance w/o the signal from the ECM, maybe 4 or 5 degrees between idle at 6000 RPM.
Old Jan 11, 2011 | 12:39 AM
Car: 88 Camaro SC
Engine: SFI'd 350
http://www.msdignition.com/Products/...stributor.aspx
Something like that one or whichever you want to ultimately run would be what your looking for. A standard dist. with spring/weights along with a vacuum advance.
Old Jan 11, 2011 | 10:48 AM
Cody Ashby's Avatar
Engine: 6.0 LQ4
awesome, exactly wat i needed to know.. Looks like ill be putting the 8366 up forsale. Its a shame cuz i spent 280 on it and got 1150 miles out of it lmao. Gotta pay to play i guess
9192camaro
16
Feb 3, 2019 12:21 AM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
Sanjay
Aug 12, 2015 03:41 PM
