what gearing to use??
Old Jan 12, 2011 | 10:49 PM
amsterdam_6969's Avatar
rebuilding a 82 z28 i swaped the old 305 with a mild preformce 350 fallowed by a 700r4 with a stage 2 shift kit and now on to the rear end now my rear end is a 3:73 posi. now i was wondering what gears should i put in the rear end(or keep the 3:73's) im building the car to cruise around the city and some 1/4 drags here and there but mostly high driven. so any info will help
Old Jan 13, 2011 | 07:51 AM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: what gearing to use??
If you do highway driving I would keep the 3.73s. Its a good blend of accelleration and with an overdrive trans the RPM isn't too high on the expressway. Any shorter of a gear and your going to be maintaining a lotta rpm at highway speeds.
Old Jan 13, 2011 | 08:17 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
what rpm's will you see with the 3.73's at 70 mph with the 700r4 ?
Old Jan 13, 2011 | 08:40 PM
vangogh4560's Avatar
Car: 1987 camaro lt
Engine: soon 383
i would keep the 3.73
Old Jan 13, 2011 | 08:43 PM
Car: 1987 camaro lt
Engine: soon 383
i don't have a tack in my car but if your doing 70 in OD and the stall converter is locked in its going to be low.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
