Had a weird engine issue the other day
Old Jan 16, 2011 | 04:06 PM
84CAMARO28inFL's Avatar
The first time i drove the car it ran great but i noticed steam coming from below the carburetor and a hiss sound, and when i drove it with the cap off it did neither of these things and i saw no steam or smoke. Here is the update: Ok I drove the car with the radiator cap off and the radiator appeared to be empty. As to if the Water Pump is leaking, i dont know, not sure if it is from that. I did add 3/4 a gallon of water the radiator took it all and i saw no smoke or steam with the cap off, except for a small amount when the car was turned off, and i saw the water level at halfway in the radiator.
Maybe the radiator was empty the first time and that is why i saw steam?
Is a Pressure Test the best thing i can do, or get antifreeze now since i added distilled water and fill it up and see if it returns? And if Pressure test, HOW?
Also, my temperature and oil pressure gauges domt workl OR i cant see them. How do i check on that?
1984 Camaro 2.8L Auto, thanks!
Frozer!!!
Jan 19, 2024 04:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
